using cat5 to extend analogue cables
cameronl
hi there, I am looking at using something like KAT5 or MadNat to send my stereo signal over a long-ish distance with Cat5e.
My only concern is with the quality - will the sound be inferior to that of a normal analogue cable run?
I will be running a RME 9632 sound card into a A75+ amp.
thanks for your time.
CaM
Nic Rhodes
I am currently 'testing' all these MadNat balun products if you can wait a week or two. I think they are currently missunderstood and offer serious technical merit.
Warpaint
I would be interested to hear any reports of S-video and/or digital audio distributed through CAT5. I know the hardware exists but I haven't seem/heard it in action.
Nic Rhodes
I literally have a set of component, RGB, SVIDEO, Composite, SVIDEO and audio, aerial, digital (ie 2 baluns sets, 1 for each end). All from memory, there may well be more. I have all the necessary CAT 5 cables as well now so testing has started. This should cover most of people interests. I would be interested to know what peple want to hear from this.
cameronl
hi there, the thing that I am most interested in is the sound quality for 2 chanel stereo - more importantly I guess is if I'm using good components will I notice a degradation in sound quality?
i.e.
RME 9632 sound card > A75+ stereo amp
thanks heeps for the information.
CaM
rhinoman
Just how well they stand up against the recognised cables.
I know from the CCTV industry that this is becoming the recognised way for composite video connections, especially over extra long runs. Definitly interested on your veiws of the audio connectors though.
cameronl
hi there, I was just wondering whether you ahve had any inital thoughts on the quality of these products yet?
CaM
The Best Movies and TV Shows Coming To Netflix in October 2020. Tom's Thumbs.
