Using an integrated amp with an AV amp for L&Rs
Discussion in 'AV Receivers & Amplifiers' started by matblack, May 30, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    406
    +10
    :confused:
    I'm confussed about this
    :confused:
    I have a Marantz SR5400 that I am using to power Kef 103/4s, Q30s and a 100C
    I'm led to believe that a stereo amp will be a better bet for music so can I add an integrated amp into the system to act as a power amp for the AV amp and to plug my CD player into direct?
    MB
  2. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Yes, you can plug your CD player into the integrated amp directly, bypassing the AV amp.
    Connect the stereo amp into the AV amp via the pre-out terminals.
  3. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Cheers mate (should just have posted this on OC :D)
    Now I need to find something which will push my Kef 103/4s! Something with decent musicality and 4ohm handling!
    MB
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Glad to be of assistance :)
