Sandra51
Established Member
- Joined
- Mar 3, 2011
- Messages
- 650
- Reaction score
- 141
- Points
- 140
I have a lot of 3.5 inch 2TB and 3 TB SATA hard drives formatted as NTFS with movies on them that I used to plug in to a USB hard drive dock attached to my Dreambox 8000. Can I do the same using one of the USB ports on the new Shield Pro or would I have to mount and unmount each drive when I wanted to remove it and plug another drive into the dock ?
Also as I have recently bought another dock which says it supports up to 8TB is there an external hard drive size limit on the Nvidia ?
Thanks for any help and info you can give me as I am getting fed up buying stuff then finding it that it will not do what I thought it would ☹
