What effect would using a subwoofer on either side as speaker stands do? Would it sound terrible? I would like a large subwoofer (maybe two) but haven't got room for speakers then sub, however might be able to squeeze in two subs if I could place my standmounts on top of the sub(s) Cheers
This can work really well. Look at older KEF spekers like the 107 and the Maidstone. Big sub used as stand and closed box speaker on top.
Cheers. Spotted Spligsleys HGS-18 & the Merdian sale ad.. why does decent stuff always turn up when you're skint? I've got the choice of- two CS-Ultra's behind my existing Left & Right speakers, or replacing the Q75's (AV use) with RDM two's - to match the Kef 200 and then getting two subs..
Somehow I doubt the older KEF speaker stand/sub boxes would really put out the same sort of output as an HGS-18, so I don't know if you can really compare them..... A number of companies did this back then - even the LS3/5a had a sub box/stand thing (AB-1 maybe? I could just be making it up..) But these were not designed for pumping out 12Hz at stoopid volumes - more like filling in the 35-70Hz range maybe, as the mini-monitors used on top usually had a pretty steep bass roll-off pretty high up. I would be wary of using an HGS (or any other "serious" sub) as a speaker stand... but maybe it's worth a try. If nothing else you could always sell the second one to me. Cheers, Dunc
For my hi fi I've got my right side Mordaunt Short speaker sitting on top of a REL Q50 after realising this would put it at almost exactly the same height as my left speaker (on a stand). Haven't noticed ANY difference in sound and it's saved me some floor space. Worth a shot!
my subs are designed to have the speakers sat on them i find that it helps the sound feel more complete i know you cant hear the difference but you can definatly feel the difference, and they look very imposing heres a photo...
I have seen quite a few very good american HT installs setup this way, as long as there are no bad phase issues it is fine to do so.
as long as you are using 6 identical subs! how else do you get all 6 speakers up to the same level! ad
Cheers for the help guys. I've decided to buy a SVS cylinder sub, as this takes up less space (so I can still fit two subs) A HGS-18/CHT-15 is just too big, at least the cylinder's go up, not out-which is no problem. If I didn't have decent floorstanding AV speakers I would probably consider dual box subs as standmounts for Kef RDM two's.
