Using a standard 7.1 amp for multi room audio
Discussion in 'AV Receivers & Amplifiers' started by tek2k, May 5, 2007.
  1. tek2k
    tek2k
    Jan 29, 2006
    13
    Hello everyone,
    I was wondering if anybody had used a standard 6.1 or 7.1 amp for multi room audio. I basically have 6 speakers and want to just play a cd on all of them at the same time. I dont want the amp to think that some are front and others are rear I just want them equal. Is this possible or will the amp try to adjust signals on the different outputs by itself?
    Thanks.
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    You could do it with stereo pairs, by running multi channel stereo mode.
