using a radio as an amp??
disastermaster
Hi there, does anyone know how to add an input socket (3.5mm?) to an old portable battery radio. Basically I want to use a radio(that is small enough to carry in my toolbox) at work as an amp for my minidisc player. Can you jump on to the amplification side of the radio and disable the actual radio side. I know that all radios will be different, but before I get deeper into models etc I just want to know if it can be done and what help is available.
TIA Disastermaster.
T
themadhippy
try the volume control,normaly the signal in is on one side, signal out the middle pin and earth on the third pin,
disastermaster
Thanks for the info I didnt realise it could be that simple! So that means that the volume control is prior to the amp circuit.
Thanks Disastermaster.
T
themadhippy
depends on the circuit layout but in genral the volume control is between the tunner stage and the amp stage,an easy way to test is to touch each of the volume controls contacts and listen for a hum
warning dont try this with a mains powered radio unless your confident in what your doing
