Using a pw7 as a pc monitor?
Discussion in 'Plasma TVs Forum' started by leedebs, Nov 1, 2005.
  1. leedebs
    leedebs
    Nov 29, 2002
    1,989
    63
    +124
    Guys,
    Seen a load of posts mentioning people using their plasmas as pc monitors.
    How would I be able to do this?
    I have a fairly old pc Pentium 111 450mhz processor. Not sure about graphics card etc. :rolleyes:
    Could I just connect the lead from the back of the pc to the plasma instead of the monitor I have now? or is that a :nono:
  2. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    Yes, that's exactly how you do it :)
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    yes you can just use the vga cable
  4. leedebs
    leedebs
    Nov 29, 2002
    1,989
    63
    +124
    Is it really that easy? the pc is about 4-5 foot away I guess will I need to get a longer vga cable and is there anything else I need to change on the pc or plasma or will the plasma just "see" the pc? woohoo :clap:
  5. w3dal
    w3dal
    Aug 4, 2002
    5,063
    Chelmsford, Essex
    +593
    i sometimes connect my laptop to my PW7 using a VGA lead. The laptop isnt anything special but it looks pretty good.
    thinking about treating myself to a wireless keyboard and mouse so i can surf the internet from my sofa.
    Dal
  6. w3dal
    w3dal
    Aug 4, 2002
    5,063
    Chelmsford, Essex
    +593
    As its using the VGA slot i think it picks it up straight away. Your know if its not working as it says no signal.
    Saying that u might need to use the AV select button the remote - i cant remember as i always use the VGA slot now for the laptop and for watching TV to connect my JS Box.
    Get yourself a VGA cable from Maplins
    Dal
  7. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    Make sure you get a decent one then, or the picture quality will be sh!t ;)
  8. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Select PC on the remote.
    You may want to change resolution to 1280*720 to fill the screen properly.
    Ken
  9. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    no probs with retention / burn when doing this as i was thinking of the old wireless keyboard and surf in bed thing too
