AngelEyes
Hi Chaps,
Most amps used for subs have gain control, however I am considering trying a power amp without gain controls. Do you think I am likely to have any probalems with this approach?
The only thing I can think of is that if I continue to use a BFD that I may not be able to set the input level correctly and still be able to balance the levels with the other speakers. I am not sure exactly how critical this is and whether a few dB out on the input levels is worth worrying about? I suppose it is if it is too high though...
If I eventually do build a Linkwitz transform, I assume this would get round that issue?
Thanks,
Adam
Thanks,
Adam
