Using a PDA as a Remote Control
Discussion in 'Home Cinema Control & Remote Controls' started by G-man.au, Jun 28, 2005.
  1. G-man.au
    G-man.au
    I want to use my IPAQ as a remote control for my TV & stereo.
    Can anyone recommend software (preferably freeware) that is good for this purpose? I'd like it to learn functions and maybe to macros.
  2. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    I found some free software somewhere on the web but found the IR sender on the IPAQ too weak to be usable from the sofa..... IPAQ 3600 ... waste of time. Works much better with a wireless compact flash card and rudeo to control windows Media player on my PC from anywhere in the house (and garden ... once I move my wireless access point closer to the window.. :p)
  3. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    My advice is don't bother, just buy a Pronto...
  4. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Which ipaq you have... some ipaqs have commercial grade ir and they work fairly well my friend has programmed his 1940 to use my eqiupment as i wont let him grease/slobber all over my remote.
  5. G-man.au
    G-man.au
    Checked my IPAQ and noticed that the IR is actually on the side adn not at the top so I think I will change my aproach & have decided to buy a Harmony remote after reading some good reviews of them.
    Thanks for all the input here guys.
