using a pc as a sound server
The Dude
Check out the 'squeezebox' threads hanging around at the moment, sounds like just what you're after.... A wireless network will be fine for streaming MP3, so don't need to worry about cabling up your house.. :)
David PluggedIn
Hi Docta
have a look at the Sonos, great build quality, great sound quality, runs wireless and supports all the major audio formats. You can set up a multi room system in 15 minutes flat, it really is that easy to get up and running..
Trending threads
