Using a Keene IR emitter with a Logitech Harmony hub
Discussion in 'Home Cinema Buying & Building' started by gooner_47, Aug 5, 2013.
  1. gooner_47
    gooner_47
    Feb 1, 2005
    40
    Disregarding the connection used for a second (from memory I think the Keene is 3.5, but the Harmony is 2.5).... if I used a convertor and plugged it in, would it work?
    I'm sure if I asked Logitech they'd say to buy their own "Precision IR cables", but I just happen to have some old Keene ones lying around that I could use if they'll be compatible.
  2. logiciel
    logiciel
    Feb 2, 2008
    53,137
    UK
    +5,777
    Why not try it?:confused:
  3. gooner_47
    gooner_47
    Feb 1, 2005
    40
    I don't have the hub yet. And if I had the hub, I don't have a convertor.
    Just thought someone may have tried it before, that's all.
