Using a DVB-T Freeview PC card
Discussion in 'Freeview & YouView' started by P4_MAN_25, Jun 15, 2004.
  1. P4_MAN_25
    P4_MAN_25
    Hi guys.
    I am Using a freeview card in my pc and i get most of the channels from using my comunal aerial on top of my block of flats, The only problem is that on most channels it judders intermittantly, I am getting 35 - 45% signal depending on what channel i am on, I have some normal b&q coax cable and am using a signal booster at the aerial outlet and a smaller in line signal booster at the pc end, what can i do? would throwing more signal boosters or a better signal booster in line make any differance? would upgrading the cable make much of a differance?
    Colin
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I solved my Freeview reception problems by fitting a new rooftop aerial, however that could be quite expensive for you, I would look into it though.
    A booster will help in some cases and better quality shielded cable is a must but you can't beat having good reception in the first place.
    Not very helpful I know:(
