Using a component router
Discussion in 'Plasma TVs Forum' started by philthyanimal, Nov 18, 2004.
  1. philthyanimal
    philthyanimal
    Help please
    Looking at 42pw7 with a component board.
    I have a 757i which i'm led to believe will output progressive scan on both pal and ntsc. i have an x box with component,svideo and rgb scart out.
    Also have sky+.
    Now the problems start. Do i connect sky via a js rgb>vga convertor, the xbox via svideo and the dvd via component. Or should i buy a js rgb to component convertor and connect them all through a component router(as advertised on av-sales)?
    would the router allow normal component from xbox and sky and progressive from dvd from just one output on the router?
