using a +b speaker terminals
Discussion in 'Home Cinema Speakers' started by ianlecompte, Sep 13, 2003.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    will using a+b speaker terminals to bi wire my b&w,s make any difference.i.e a terminals to mid and b to treble.any advice would be a help
  2. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    i meant tweeter,sorry
  3. SystemBlack
    SystemBlack
    It may seperate the frequency range slightly but you may get the same effect running two connections from either a or b since they are normally connected together via a switch (a/b) to the same amp output. I think that applies to most amps. You would have to make sure that the individual impedances for the mid range and tweeters are above the recommended minimums for using a and b terminals.
