I have one downlead (approx 10mtrs) to a TV and have wired off from that at the moment to a 3 way splitter at rear of TV to supply 2 other rooms and signal /picture is good.
I want to now get a fourth room supplied and have been told that I might get signal loss on the 4th. I have a difficult wiring job to do all this from the Mast and that is why I have took them from the original good cable at the rear of the first TV by a splitter there.
I have a friend who has a spare 4 way 10db screened Masthead Amp type splitter PUM141 with a PSU for it, can I use this as a normal 4 way splitter to test to see if the 4th TV is OK and if the signal is not good could I fit the PSU at the rear of the TV to boost the signal instead of at the Mast?.
Any help much apprieciated.
WB
WB
