Using a 12W Charger on a mini retina
Discussion in 'iPad Forum' started by leebroath, Feb 7, 2014.
Tags:
  1. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    A 10W charger came with the rMini iPad but can a 12W charger be used instead?
    Was looking at a way of charging the iPad a bit quicker and wondered if this would work but at the same time not affect the iPad in any way
    Might just stick with the 10w lol
  2. bransoj
    bransoj
    Oct 29, 2009
    2,782
    103
    +477
    I use the standard charger i got with my iPad 3, is that the 12w one?, with my iPhone 5 all the time and my 3GS prior to that...never caused an issue.
  3. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    It says on the side of the adapter mate which is L shaped :)
  4. bransoj
    bransoj
    Oct 29, 2009
    2,782
    103
    +477
    I'm at work so cant check but its the L shaped looking one i've used, as above, on a couple of iPhones and never had an issue.
  5. norealplan
    norealplan
    Mar 26, 2005
    5,142
    Backpacking around the world
    +733
  6. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    If the 12w is faster at charging I wonder why they don't supply it with the iPad retina mini as standard
  7. exocet360
    exocet360
    Apr 2, 2013
    17
    Middlesex
    +6
    Hi - The ever confusing power ratings of the Apple iOS device chargers !!
    My understanding re the Apple supplied adapters is as follows :
    iPhone (all ) : 5w
    iPad 2nd gen : 10w
    iPad 3rd gen : 10w
    iPad 4th gen : 12w
    iPad mini : 5w
    iPad mini Retina : 10w
    iPad Air : 12w
    Being USB chargers they all output 5V but the wattage varies
    5W is a 1 amp charger / 10w is a 2 amp charger / 12w is a 2.1 amp charger.
    The 12w adapter can be used to charge all iOS devices safely..
    The 5w charger should only be used on the 5W devices..
    The power / amperage is pulled from the charger by the device and not pushed..
    This means that an iPhone plugged into a 12w charger will probably still only draw 5w and will not charge any quicker. However an iPad plugged into a 5W charger will only be able to draw 5W and will therefore charge at a slower rate and the charger may get hotter than usual.
    The power rating should be printed on the adapter but you may need a magnifying glass to read it !!
    i.e. iPad 1 Charger - on Label : 10W USB Power Adapter
    iPad 4 Charger - on Label : 12W USB Power Adapter
    Recommendations :
    If you have multiple iOS devices with differently rated chargers :
    Label the chargers with a larger readable label - i.e. iPad 12w
    12w chargers can be used to charge any device
    10w chargers can be used to charge any device but probably best not used on the iPad 4 and Air
    5w chargers should only be used to charge iPhones and the original iPad Mini
    Hopefully the above info makes sense..
