using 4 ohm speakers on a pioneer vsx-d2011
Discussion in 'Home Cinema Speakers' started by paul1672, Nov 18, 2003.
  1. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    as the title says,is it ok to run 7x4 ohm speakers on a pioneer vsx-d2011 amp?
    i am asking as i'm currently considering upgrading my speakers yet again and i like the look of the jamo thx d6lcr and jamo d6sur speakers and these are all 4 ohm speakers.
    the amp says it accepts 8ohm speakers????
    any info would be appreciated
    paul
  2. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    no-one have any ideas?????
  3. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    it will be fine
    if you search someone asked this recently
    regards
    leigh
  4. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    cheers mate
    i did try a search but couldn't find an exact answer.
    much appreciated anyway
  5. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    as far as i can remember it can cause the amp to overheat
    but this is only at reference levels, and shouldnt happen if well ventilated.
    if anything the amp would turn itself of if it was struggling(so it wouldn't get damaged)
    pm fred123go as he had the same amp and was using 4ohm speakers
    are you buying your jamos new?
  6. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    not sure yet,am looking around first,best price i've found is £275 per speaker for the fronts but am waiting on a quote for the rears.
    but if i could find a good set of seven second hand id be very very interested
  7. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
  8. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    do you know if the front centre would be ok mounted on a tv stand freestanding as the pj screen sits within a window frame?
    also,do you reckon they'd be ok with current rear speakers until i can find some jamo rears?
  9. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    should be fine freestanding(maybe some blutak on base to keep it sturdy)
    snap these fronts up if i was you and worry about the rears later
  10. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    by the sound of it you already have a set?????
    if so,are they really that good?
  11. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    i dont have these, but i nearly got them
    and if matey still has these for sale then it is a huge saving
    regards leigh
  12. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    bugger,they're sold.
    would you mind mind if i asked why you didn't buy them???
  13. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    size issue really
    the way my front room is layed out there was no where to put them, got kef thx fronts/centre of these forums in the end
    but am looking for surrounds ,hence i asked how much you are to be quoted.
    regards
    leigh
  14. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    well,i'm still waiting for a price for the rears but am expecting them to be around the £250 each mark.
    are the kefs good value?
    just looking for a good complete set of thx speakers (set of 7) to go with me pioneer amp although i'm not interested in the mordaunt shorts.
    anyway,if/when i get a definite quote i'll let you know.
    many thanks for your help.
    paul
  15. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    i am yet to hear my kefs:mad:
    as my amp shorted out 1 day before thay arrived
    should be back next week, people that use them say they are very good, plus they can be picked up at reasonable prices
    anyway good luck on your speaker hunt
  16. paul1672
    paul1672
    Jul 31, 2003
    2,553
    71
    norfolk
    +37
    ne chance you could push my way the model number of ur kefs m8???
  17. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    no problem
    kef reference tdm23f (2 of these)
    tdm 23c
    you can find a review on HCC
    someone is selling a pair of tdm23fs with matching stands on the classified forum
    hope this helps
    leigh
  18. fred123go
    fred123go
    Sep 16, 2003
    1,040
    39
    Cobham, Surrey
    hey there Paul,
    I had the Pioneer amp and The Mordaunt Short 500 THX package, every speaker was rated at 4 ohms, apart from the rears i think.
    I was playing it at reference level throughout films and all it did was get pretty hot, no difference to sound, and was fine.
    Fred
