Usefull to buy a scaler ???
Discussion in 'Projectors, Screens & Video Processors' started by Fyberoptix, Sep 27, 2004.
  1. Fyberoptix
    Fyberoptix
  2. JonMace
    JonMace
    Nov 20, 2002
    2,570
    83
    Kent
    +210
    Niether of your links work
  3. Fyberoptix
    Fyberoptix
    should be fixed now
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Deinterlacing it converting an interlaced signal into progressive scan format. Scaling to converting a signal of one resolution type to another. A video processor will usually do both of these functions (Lumagen, iScan, Crystalio etc).
    The avermedia box is a scaler and deinterlacer, the think on your second link is also a scaler and deinterlacer. I wouldn't expect the second to be any better than the first. For real improvements you need a budget of several hundred pounds minimum.
    DIY beamer??? This doesn't sound good. Could the DIY aspect be the cause of a blurry picture? I know it's difficult to decribe a picture, in words, but if you describe better how it is blurry someone may be able to work out if it is a processing issue or a hardware issue.
