Useful Info from Sagem re Axium HDCP etc
Discussion in 'TVs' started by dave68, Dec 10, 2004.
  1. dave68
    dave68
    I just had a conversation with the very helpful Stuart Wright at Sagem
    In summary:
    - Sagem is unlikely to solve HDCP non compatibility on the existing Axium as they cannot identify a cost effective solution for this
    - A new 45" set is due to be in the shops in Q1 2005
    - New 45" set will be HDCP compatible
    - The new set will have a couple of extra features over the existing one (Subwoofer, 3000:1 contrast ratio)
    - Effectively the new set will replace the current 50" one
    - The new set is likely to be priced either at or below the current model
    Hope that is useful
    Dave
  2. blackwavesid
    blackwavesid
    Oct 4, 2004
    9
    Thanks Dave
    Let's hope it's out sooner rather than later!
    Sid
  3. Phil Harris
    Phil Harris
    That conflicts with what I have heard from Sagem, Dave. I have been assured that the HDCP upgrade will be provided. This also came from Sagem.
    The guy I spoke to was suggesting it would be available in January, and would be an engineer installed upgrade.
  4. dave68
    dave68
    Phil, it is indeed contradictory, but thats what Stuart told me....I asked him about the liklely hood of an upgrade and he didnt think it was at all likely as he said that effectively they would have to replace all the circuit boards...Im no expert (in fact im whatever is an opposite of an expert re this stuff) just a messenger :)
    You pays yer money takes yer chance...:) I shall wait and see what transpires in Q1.
    Of course who is to say Sky wont change their mind/story....so might all be a total red-herring anyway.
  5. acanning
    acanning
    Mar 11, 2002
    109
    16
    Hampshire
    For what it's worth, I spoke to a lady called Claire in the Technical Support dept at Sagem and she assured me that the upgrade would be available mid January.
    Time will tell!!
  6. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
  7. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    2,793
    +625
    will there be a 50" display available for the new axiums?
    Will be gutted if the 45" costs 2k.
  8. armitasp
    armitasp
  9. armitasp
    armitasp
    Sorry link doesnt work, but on the information for the Axium 50 on the support site it says:
    With Sagem Axium™, step into the age of High-Definition television.
    An exceptionally high quality picture : resolution 1280x720, 1 million pixels per colour
    Intelligent connectivity : analogue and digital inputs and oututs, HDCP access control
    The power of Virtual Dolby Surround sound, Timeless design, Just some of the features of DLP™ and LCD technologies by SAGEM.
  10. wmadoss
    wmadoss
    Also noticed that but unfortunately that doesnt regard the 50" model only the new 45". If u read it doesnt say anywhere on the features on the 50" that it supports HDCP but if u check the 45" model it says this.
    I see how it can easily be misinterpreted that the 50" model also supports HDCP which is not the case.
