Used to have a Yam dspa595a....
Discussion in 'AV Receivers & Amplifiers' started by st0ckman76, Oct 21, 2003.
  1. st0ckman76
    st0ckman76
    Hi, I used to have a Yamaha DSPA595A but gave it to my parents for their system. This amp was amazing and suited all my needs and worked with the Mission speaker set up i have perfectly, speakers:
    ( 773E + 77DS + 77C1 + M70as )
    Basically i am in the market for a new amp and haven't a clue whats out there. Would like something close to the 595 or better. Any suggestions?
    Ray
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Any of the Marantz range SR4300, 5300 etc are cheap at the moment and are good for movies and music, worth a listen.
  3. Gatto
    Gatto
    Check out NAD T742, Good power reserve to drive several speaker range
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    why not get a DSPAX640SE ?, I used to own a 595a [great all rounder as you say], upgraded to an AX1 to save on boxes [complete waste of money BTW], and now use a 640SE for centres & rears, with a proper 2channel amp to drive my main speakers for CD listening.
    HC amps just don't hack it if you are into serious CD listening IMHO,
    But for under £300 the 640SE is a bargain
