Question used jvc x30 or something new
Discussion in 'Projectors, Screens & Video Processors' started by gary3529, Jan 8, 2018.
Tags:
  1. gary3529
    gary3529
    Dec 12, 2006
    23
    Having trouble deciding on the above
    Room is 3.6m x 4.8m ceiling height 2.6m walls are painted dark red upto 2m height then white with white ceiling so not overly bright but far from being a bat cave
    Projector to screen would be 4.8m minus projector depth
    currently projecting onto a grey painted diy screen 118" 16:9
    I had been looking at buying a used ivc x30 but was just wondering what peoples opinions are on how this would fair against a new epson tw6700 or tw6800 or similar priced new projector
    Budget is ideally under £700 if buying used or around £1500 if new
  2. mb3195
    mb3195
    Dec 27, 2007
    1,890
    2
    116
    Peterborough
    +1,839
    Ive has a JVC X30. Very difficult to beat at that price point if you can get a good one.
    A new bulb and you’ll be competing against £3k projectors.
  3. gary3529
    gary3529
    Dec 12, 2006
    23
    Was just unsure how much projectors had improved over the last 5 years
    And the fact I would be buying an x30 blind having never seen one it’s impossible for me to compare
  4. mb3195
    mb3195
    Dec 27, 2007
    1,890
    2
    116
    Peterborough
    +1,839
    The x30 are an outstanding projector. Blacks are actually better on them than the newer equivalent models.
    Honestly, for that price, you’ll have to spend £4K plus to start noticing significant improvements, and that will be mainly from 4K and HDR content.
    I’ve currently got an Epson 9300, I’m upgrading it for a JVC X7900 which comes tomorrow. The X30 is comparable with the 9300. The 9300 has a sharper image and possibly less smearing, the JVc better blacks.
  5. gary3529
    gary3529
    Dec 12, 2006
    23
    Thanks will keep an eye out see what comes up
  6. jfinnie
    jfinnie
    Oct 1, 2004
    4,532
    Norwich
    +1,907
    X30 is a cracking unit, as has been said you need to spend more than £1500 to better them new.
    My white one will be going up for sale in 2-3 months once the dedicated room is done.
    Edit - they're not the brightest though. 118" grey is quite a lot of screen to light up.
  7. gary3529
    gary3529
    Dec 12, 2006
    23
    I had planed to get a new screen later in the year anyway
    Possibly CIH about the same width as I have now
    And could paint my current one white
    In the meantime as I did think it may not be bright enough
  8. mambo1888
    mambo1888
    Dec 8, 2009
    4,061
    Fife
    +640
    Hi Gary
    Im upgrading from an X70 to the X7900 which should be arriving today. I have the X70 up for sale, its a bit more than your looking to spend on a second hand unit, but if you are local you are more than welcome to come round for a demo and compare the two.
  9. gary3529
    gary3529
    Dec 12, 2006
    23
    Whereabouts are you I’m Northamptonshire
  10. gary3529
    gary3529
    Dec 12, 2006
    23
    Just see your for sale thread so a little to far for a viewing
    Will have a think whilst at work
  11. mambo1888
    mambo1888
    Dec 8, 2009
    4,061
    Fife
    +640
    Im in fife mate, a bit far for a demo lol. Id say if you can if you can find an x30 close by then try and get a demo, and then demo some new projectors at your price point at your local av dealer and go from there. Id have to agree with others that you might struggle to get better performance from a new projector at that price point.
