Used Denon AVC-A1D vs New Yamaha?
Discussion in 'AV Receivers & Amplifiers' started by Waste, Aug 28, 2004.
Tags:
  1. Waste
    Waste
    Hi all,
    I am new here and have a question about buying a new amplifier.
    Things do progress and electronics get cheaper. What will have the best
    sound quality of an used Denon AVC-A1D compared to a new Yamaha RX-V2400, both 2-channel and multi-channel considered?
    I know that the Denon is lacking some of the new sound formats but that is
    not a big issue for me.
    So what do you guys think, shall I go for the old school or the new school?
    Best regards,
    Freddy
  2. Smurfin
    Smurfin
    Aug 13, 2002
    21,422
    +4,354
    Freddy
    I think (though I may be wrong) that the 2400 has a calibration feature similar to the Pioneers, which - imho - would elevate itself above the A1D. The A1D was a good amp, and still probably is in terms of processing and power....but it all depends how much the A1D is costing (shouldn't be more than £400 now) and where it fits in with your budget.
  3. tommypeters
    tommypeters
    Aug 16, 2004
    7
    I was all the time thinking of buying a 2400, and even ordered one. But since the shop had it back-ordered all the time I took a look around for used stuff - and ended up with an AVC-A1D...
    Pros for the Yamaha: Better movie sound, more bells & whistles, new.
    Pros for the Denon: Better 2-channel sound, better for driving "tough" speakers.
    And the Denon can be had in black :)
