Used Arcam CD players - which & how much?
Discussion in 'Arcam Owners' Forum' started by StevieDvd, Aug 9, 2004.
Tags:
  1. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    I just missed an Arcam CD62T Plus on Ebay (in silver) which went for £165 in the end.
    As a starting point given that Arcam are as good as the reviews indicate was this a reasonable price?
    If you were buying an Arcam for occasional use, only via Headphones which would you go for at the lower price end?
    Is there a good place to get used models in UK?
    Thanks in advance.
    Steve
  2. nikyzf
    nikyzf
    'Hi-Fi World' mag is good for used gear- lots of dealer ads in the back.
  3. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    I'm running an old 170 transport and Black box 3 DAC through my new AV300 and it sounds pretty good.Both bits on ebay at the moment. I paid £175 in total for mine from a friend which seems a reasonable price form something 9-10 years old.
  4. Icarus
    Icarus
    I had exactly the same kit and thought it good. Sorry to offer bad news but I demoed it against quite cheep kit at my dealer and it was lacking in many areas. If you have some spare cash I suggest you hear something newer.
  5. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    I'm a bit wary of something over 5 years old, would prefer newer. Guess it's the usual thing of brand new XX model versus older but quality YY model.
    I'll keep on looking,
  6. Miron
    Miron
    Sep 26, 2002
    1,435
    Vienna, Austria
    +54
    I saw Alpha 9CD going on ebay UK for 300 £
    This is a bargain to go for
  7. 803cd
    803cd
    Oct 26, 2003
    One thing to remember - CD transports don't last forever. We have 2 ten year old Alpha 5 CD players at home (both from new) and both have needed new transports (at 6 and 7 years old respectively). Once you get past Diva vintage players I guess the risk increases.
  8. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Had the 170 and DAC serviced by Arcam recently and they sorted out a minor dry joint problem in the DAC since then it has been fine. They say however that any laser problems and they have no spares. I will keep my fingers crossed as I am about to buy some new speakers.
