Use Y-Adaptor w/Paradigm Ps-1000 ?
Discussion in 'Subwoofers' started by cjob68, Mar 2, 2003.
  1. cjob68
    cjob68
    It says in the Paradigm Ps-1000 manual that you can use a y-adapter out from your LFE channel into the subwoofer to gain DB. Do they mean use the y-adapter at the receiver ( if it has l/r output for the sub ) or at the sub ?
    Thanks In Advance
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    You use it at the sub end if your reciever only has one LFE output.
