Use the subby crossover or the amp crossover?
Discussion in 'Subwoofers' started by snocrash, Dec 2, 2003.
  1. snocrash
    snocrash
    Dec 27, 2002
    103
    G'day all, here's an open ended question...
    Since most amps have a cross-over point adjustment (100 - 200Hz) and most subby's also have an adjustment on the back of them (sometimes 100 - 150Hz)
    Would it be preferable to use the Amp for cross-over cutoff or the subby ?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Use the amp's x-over, the subwoofer should be set to the max. or bypass (if available), else you cut-off the LFE which is not effected by the amps settings.
