Use my old Xbox for HD?
superdon
I have just recently bought a new HD plasma, and its looking great with my standard DVD player, and through cable. However, I am trying to find the best (and cheapest!) way to get true HD stuff on it.
I was looking at the Pinnacle Showcenter to stream stuff from my PC, and then thos morning was looking around and found out about XMBC.
I have an Xbox tucked away that I havent used in ages. Its not chipped.
Should I get the box modded, and will it give me the ability to play all the HD downloads I get? Or should I stick with the Showcenter idea? Or look at an Xbox 360?!?!
Grrrr....want to be able to watch HD!
Cheers :)
If it was me and I had a little bit of money on me spare! ;)
I would trade in my xbox and buy a 360 you will not go wrong. XBMC is good and fine but the 360 is out of the box hd.
Might do this myself after xmas. :smashin:
superdon
So, with a 360, i'll be able to connect to my PC and stream HD stuff?
How much do you reckon my standard xbox, with two controllers and 8 games might go for?
Yes you can stream video/images/music all to the box.
Regarding your xbox its maybe worth £40.00 (Argos currently selling off the old xbox for £49.99 last time I checked) you could check the ads on the forum to see what the going price is.
scumball
Argos XBox is £80 and XBox 1 can not stream HD. X360 can only stream HD MPEG2/WMV out of the box.
superdon
So I take it then xbox 360 is not the way forward for me then.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
