usb wall plate?
Discussion in 'Cables & Switches' started by garyc, Sep 12, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    895
    Jersey, Channel Islands
    +14
    Anyone got any ideas for mounting a USB on a wall plate?
    cheers
    Gary
  2. SeriousPigeon
    SeriousPigeon
    Sep 9, 2005
    154
    43
    Amersham
    +109
    Get in a order to RS parts and get a USB socket. Buy and blank wall plate. cut out the correct sized hole and mount the socket. Then solder up the cable.
    I have no idea whether it will work or not.
  3. SeriousPigeon
    SeriousPigeon
    Sep 9, 2005
    154
    43
    Amersham
    +109
  4. garyc
    garyc
    Dec 21, 2002
    895
    +14
  5. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    You do know that USB has a limit of 3m unpowered and 5m powered. If you want cables longer than this you must use powered hubs which will read and re-transmit the signal.
    Rajiv
  6. garyc
    garyc
    Dec 21, 2002
    895
    +14
    yep
    but thanx for the post
