USB vs USB 2.0
Discussion in 'Photography Forums' started by Hill1, Aug 3, 2005.
  1. Hill1
    Hill1
    Jul 30, 2005
    112
    east kent
    Looking at various digital cameras, I am confused by the USB.
    Some models list only USB, and others USB 2.0
    My PC has USB 2.0, so if I get a phone which just says USB will it still work.( I am assuming USB refers to USB 1.0)
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    35,602
    5
    16
    CyberSpace
    +10,387
  3. MattB1
    MattB1
    It will still work fine but you just wont get the speed advantage that you'd get from a USB 2 device.
    In simple terms USB2 is backwards compatible.
    Matt.
  4. Hill1
    Hill1
    Jul 30, 2005
    112
    east kent
    Thanks guys.
  5. Dr Diversity
    Dr Diversity
    USB 2 is about 480MBS whilst USB 1 is 2MBS. It will work at the slowest speed if you mix the two - but it will work.
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Woah! Its not that fast.
    USB Version 1.1 supports two speeds, 1.5 and 12 Mb/s. USB 2.0 supports 1.5, 12 (ie backward compatible with v1.1) and 480 Mb/s.
    MBS = M Bytes per second
    Mbs = M bits per second
    1 byte = 8 bits
  7. Dr Diversity
    Dr Diversity
    Thanks Ian, that's what you get for relying on memory when you get to my age. Oh and muddling B and b
