USB sound DTS/DD etc.
M4tt
I am running MCE on a small form factor PC with integrated 2 channel sound. I am looking to upgrade this to surround sound etc. As the PC only has 1 PCI slot and it would have to be one of the small sized ones too I have been looking at some of these USB external sound card offerings (looking at getting 2nd hand), such as the Creative Sound Blaster MP3+. Has anyone any experience with these sort of devices, they have, SPDIF (Optical) input and output, but does anyone know if I would be able to get a DTS or DD signal from the unit to my amp, i.e. if I played a DTS/DD DVD in the PC.
I have not found any info that makes me sure either way as to DTS/DD passthrough? (if thats the correct term)
Any help would be gratefully received.
:lease:
boez
I use the M-Audio Transit USB dongle mainly cos it means that I get sound out of my HTPC that hasnt been mangled to 48khz by the Windows kmixer!
However it would seem ideal for you. M-Audio make good sounding PCI cards and are generally seen as a high-end company.
Its got line and optical out and either line or optical in (only one at a time though). It passes out DTS/DD5.1.
A search of these forums reveals some futher opinions.
Cost me around £50 I think.
HTH
Andy
D
Deleted member 39241
I use the Creative USB Soundblaster Live 24bit - works great for me, optical and coaxial connections, good drivers. About £50 also I believe.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
