USB sound 'card'
Discussion in 'Computer Components' started by Stereo Steve, Dec 13, 2003.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    Anyone know of a USB sound card that has a minijack SPDIF output? I have an Abit one that has optical outputs but I have run out of iptical inputs on the reciever.
    I have a PC upstairs that has audio and video files on it and I want to stream them over the network downstairs to my laptop which has a TV output. I find the audio output of the laptop a bit naff though so would like a dedicated USB device. SOme video files I have have AC3 soundtracks and although I can convert them on the laptop to stereo, the mix is always appaling so I would rather stream them straight through as AC£ to my amp.
    Any ideas?
  2. Epithet
    Epithet
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,255
    Southsea, UK
    +86
    Have you looked at the Audigy 2 NX .
    Looks like a nice bit of kit and retails for around £99.
  4. Donnacha
    Donnacha
    Jul 4, 2002
    7,296
    York
    +3,584
    Try edirol also, they have some USB digital cards.
    I think its www.edirol.co.uk
  5. Epithet
    Epithet
    Stellavision
    I agree, I believe the NX does include a coax out. I tried to post a link to the relevant Creative labs page but it does not work.
    Steve
    Search the knowledgebase on the Creative labs site for the Audigy 2 NX and you should come across a link concerning "connectivity". This clearly appears to show a coax SPDIF out.
    Tony
  6. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    OK, I'll check it out. Cheers.
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,255
    Southsea, UK
    +86
    You can see the full spec on Creatives website HERE
    It supports coaxial and optical out.
  8. Magsy
    Magsy
    Oct 18, 2002
    107
