USB-serial converters + software that work
Discussion in 'TAG McLaren Audio Owners' Forum' started by Teejoo, Aug 23, 2004.
  1. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Hi all,
    Since there has been a lot of discussion on both the old forum and this one about which USB-serial converters that work with the Tag gear and if the new IAG backup tool works, I decided to get one and do some testing. (To fill up my Beta testing gap ;) ). I tested both the IAG backup tool and normal software update.
    I found one that is quite cheap (19 Euros!) and it works flawlessly with both my Dell and Acer laptop. The brand is ATEN, model UC-232A.
    So, perhaps something to try since it's cheap cheap! :D
    Have fun! :thumbsup:
  2. jolaca
    jolaca
    Thanks Teejoo. Where did you get it?? Is it available online??
  3. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    I bought it in a store. But if you Google around, you can see tons to buy online.
  4. diego120368
    diego120368
    hello I am new in this forum and I don't have the clear ideas... :rolleyes:
    you have gotten something that supplants the cable tagtronic for 19€.? :confused:
    you please clarify me, :lesson: because I have problems with my dvd32r and I need to make an upgrade.. :lease:
    thank you
  5. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Hi don't get all confused, we are talking about a convertor to allow the TAgTronic programming cable to be used with modern laptops that don't have a serial port (the convertors listed are USB-serial convertors). You still need the TagTronic progamming lead in all instances to interface with the TAG kit for progamming TMREQ and software updates. The TagTronic progamming lead was around £70 so beg steal or borrow one if your just trying to update the DVD32R.
