Usb Otg
Discussion in 'Headphones, Earphones & Portable Music' started by TooMuchChoice, Jun 17, 2005.
  1. TooMuchChoice
    TooMuchChoice
    Hi!
    I am looking for a 20GB player with USB OTG. Does anyone have any ideas? I have been looking at the Iriver H320, but after Amazon's clearout this week it seems pretty clear that this is a player without a future. Any advice would be greatly appreciated.
    Thank you!
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,219
    48
    +61
    Try the iAudio X5, which has USB2 OTG. Not sure how much faster it is though. It depends on what you want USBOTG for. If it's camera connection, then the iPod Photo with the Camera Connection cable is also worth looking at. Confirmed list of support here, which let me tell you is a heck of a lot better than the iRiver for a start. http://www.apple.com/ipod/compatibility/cameraconnector.html
  3. TooMuchChoice
    TooMuchChoice
    Thank you for the advice. I really like the look of the X5, but I'm not sure my piggy bank can spring to the £80 difference between the two! Even better is the X5L with 30hrs of battery, but I guess that would be another £50 when it is released!
    I keep seeing Iphotos very cheaply maybe I'll have a punt on one!
  4. lukey
    lukey
    the archos gmini 400 has usb on the go so does the sony vaio pocket vgf which is reduced down to £199 as its end of line, also has a 40gig hard drive
