USB HVR900 Wintv2k keeps crashing in Vista 32 bit -any alternative of Fix Pls?
rolfee
Hi All,
I cannot get wintv2k to run without crashing in Vista HP 32bit. All my details are below (copied from support email). Has any one else found a fix, or can you recommend a stable bit of software to replace wintv completley?
Rolfee
Product = WinTV HVR 900 USB
I am running following spec machine
• Intel Duo core 2 CPU 6600 @2.40Ghz
• 2 x Nvidia 8500gt SLI (SLI not turned on) (duel monitor) – most recent graphics drivers installed
• 2046mb RAM
• ASUS P5 SLI motherboard
• Vista Home premium 32bit edition.
• Connected directly to USB port not via hub
I cannot run Wintv2000, every time it opens the application crashes, I reboot the machine and it opens first time only, then any channel change crashes the program. Below is the error message.
Problem signature:
Problem Event Name: APPCRASH
Application Name: WinTV2K.EXE
Application Version: 5.2.25067.0
Application Timestamp: 45f0726a
Fault Module Name: QUARTZ.dll
Fault Module Version: 6.6.6000.16386
Fault Module Timestamp: 4549bda3
Exception Code: c0000005
Exception Offset: 000cbf1f
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 2057
Additional Information 1: 2357
Additional Information 2: ce5ebcad3ae36092a6d9cab90f4e68fb
Additional Information 3: 0a16
Additional Information 4: e7e98b98814c02099d460175cb80b291
I have run your hardware clear program several times, re-installed the driver/software several times (including only installing the wintv software and nothing else), same result, I even tried wintv beta version and same issue. I ran through every fix on your website + cannot find a fix on any of your knowledge base or forums.
Please can you advise how to fix this as I have a product I cannot use.
rolfee
Hi All,
Got a response from Hauppauge and tried it and seems to fix issue. I set it to allow overlay, turns off Aero visuals but gives you fully functional wintv2k.
"Can you go to start/programs/hauppauge wintv/primary and then select one of the options (Force Primary, Allow Overlay or DIB draw). Try running the application with each change."
