martinf
Hello,
I'm looking for some kind of timer, which will shut down for example every hour or so and then turn on power to the USB hub.
I know about the usb hubs with switch on/off button, but that's not the solution :/
Or if you have any ideas, basically i need to display light usb cables in our retail store, these cables will be plugged into USB Hubs and connected to the PC. The problem is these cables are not recommended to be light up the whole time, so i need some kind of timer which will shut them down for some time to cool down. Or is there some kind of software which will disable PC usb slot?
Thank you for answers/ideas.
— As an Amazon Associate, AVForums earns from qualifying purchases —
