USB hub query
Discussion in 'Desktop & Laptop Computers Forum' started by Brogan, Jul 3, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    I currently have my PC linked to my AX5i via a long USB cable.
    I also have a very long VGA cable and 2 very long PS2 cables going through to the lounge so I can hook my PC up to the plasma.
    I was wondering whether I could stick a self powered USB hub in the lounge and take the existing USB cable from the amp and connect it to the hub.
    Then I would just need a standard USB cable for the AX5i and a USB mouse and keyboard, all connected to the hub.
    The benefit would be only 1 cable going back to the PC, instead of 3.
    Would this work?
    I think so but just wanted to confirm if anyone has already done something like this.
  2. Kramer
    Kramer
    Yep, that should work OK. 5m is the recommended maximum length for a USB cable IIRC although I've seen 10m + work without issue.
    :smoke:
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Nice one.
    I suppose I could just go for a wireless solution but as I use the PC a lot, I'd be forever recharging/replacing the batteries in the mouse and keyboard.
  4. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    OK, I've come up with an even better solution.
    I'm going to get a keyboard with a built in USB port which I can plug the mouse into.
    Then all I need is a 5 metre USB extension cable plugged straight into the back of the PC.
    Hopefully there shouldn't be any issues with the mouse due to the length of cable (5 mtrs + 1.5 mtrs + 1.5 mtrs)...
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I've got 8m without a powered repeater working fine with a touchscreen.
  6. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Thanks for the confirmation John.
    Looks like I've got my quick and easy solution for keyboard and mouse in the lounge.
