USB Freeview Film 4 Problem
L
lib319
Hi there,
I have a Freecom DVB USB Freeview stick like this that I use on my PC
http://www.freecom.com/ecproduct_detail.asp?ID=2234
I don't seem to be able to even get a channel listing for Film 4 when I rescan my channels. I am using a regular rooftop aerial which gets most Freeview channels ; although the ones it doesn't receive are still listed in the EPG channel list.
Does anyone know why Film 4 isn't being picked up? Could it just be a weak signal? I live in the AB11 area of Aberdeen, Scotland.
thanks for any help
lib
L
lib319
hi there,
ch31 gives me a Gaelic Radio Station, I think the channels are different when running from a pc rather than a set top box. Don't knoew the transmitter though
lib
JayCee
Outstanding Member
They aren't...check your setup and if you have the option to select LCN (Logical Channel No).
What's your postcode?
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
