USB for extra memory
Discussion in 'Computer Components' started by raymondo17, Mar 8, 2013.
  1. raymondo17
    raymondo17
    Dec 10, 2008
    I am using a 16GB USB stick as extra RAM, the trouble is that windows will only use around 3GB of this stick.
    How can get Windows to use the full 16GB as RAM?
    I am using Windows 7 Home Premium
  2. Rich Marshall
    Rich Marshall
    Nov 14, 2006
    3,717
    Kirkby In Ashfield
    +585
    Are you using Windows 32bit or 64bit?
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,789
    Norfolk
    +2,509
    You can't have 'extra RAM' connected via USB - USB runs 100-1000x slower than system RAM.
    Presumably you mean something like readyboost that uses a USB stick's characteristics to mask some of the flaws in a standard hard drive? If so then I believe there's a 4GB limit on FAT32 formatted sticks which may be the problem.
    Readyboost shows the biggest difference on low end setups though, and I wouldn't expect increasing usage from 4GB to 16GB to be particularly noticeable.
  4. raymondo17
    raymondo17
    Dec 10, 2008
    I am using 64bit Happy Rich.
    Endless has also answered my question.
    Using the USB seems to have speeded up my PC
