USB external hard drive
Discussion in 'Playstation Forums' started by FunkyMonkey, Jun 12, 2008.
  1. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Hi all.
    I have transferred some video, photo and music files to a WD external USB hard-drive.
    Trouble is, when I try to view the folders on the PS3, it does not recognise any sub-folders.
    Is there an easy way to fix this by changing a setting on the PS3 or do I need to re-arrange the whole folder structures on the USB hard drive?
    Alternaitvely, can I put some "media server" software on the USB hard drive?
    I know that you can on NAS drives, but I'm guessign that is nto applicable to USB hard drives as they are not network driven.
    :confused:
  2. PlasmaNewbie
    PlasmaNewbie
    Oct 21, 2004
    146
    +10
    I believe the USB drive has to be formatted as FAT32 rather than NTFS.
    You will have to reformat the external Drive to use it :(
    I ended up using a 16gb Flash drive to transfer stuff over.
  3. sparklesmcgraw
    sparklesmcgraw
    Apr 1, 2008
    421
    +17
    Press Triangle
    Display all
    That should do the trick
  4. Iron Man 2
    Iron Man 2
    Jan 19, 2007
    811
    Cooley Peninsula, Ireland
    +70
    Thats correct, this will only work if the drive is formatted as FAT32. Easy enough done. Think I googled how to add an external hard drive to ps3 and just followed the steps
  5. mr_yogi
    mr_yogi
    Sep 12, 2003
    1,639
    +173
    WD MyBooks and I assume the Passports and all other extrernal drvies already come pre formatted in FAT32.
    As has already been mentioned "TRIANGLE" and "Display ALL" will take you to the root of the drive, from where you can nivigate to your files.
    By default the PS3 will look for folders names "VIDEOS", "MUSIC" and "PHOTOS", so if you create these and store all your data in them you will not need to "Display ALL" to find your stuff.
    One thing to consider is that (*I think*) you can only go one folder deep once inside each of the above folders. I made the mistake of putting all my music in "/MUSIC/ARTIST/ALBUM" and the PS3 can't find any songs (Can see the folders though) unless I use "Display ALL" :rolleyes:
    I put a few tracks in "/MUSIC/ARTIST+ALBUM/" and they could be found and played fine, I assume the "PHOTOS" and "VIDEOS" folders are the same.
  6. Maxamus
    Maxamus
    Apr 30, 2008
    2,081
    63
    +170
    All WD MYbooks come pre-formatted as FAT32. I have one and am using it with my PS3.
    Make sure you have made the folders with proper names. MOVIES, MUSIC, GAMES, PHOTO etc
  7. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Sorry I didn't make myself clearer, but the disk IS FAT32. And as I suspected this si my problem - I have the correct folders, but the PS3 can only see 1 folder deep.
    I have since re-arranged the files with this in mind so now it's all visible.
    Thanks for advice.
  8. mutha
    mutha
    Jul 30, 2007
    47
    11
    newport
    +3
    Hi all
    i have an external harddrive and it was NTFS and i have formatted it as FAT32 now but PS3 still not recognising it
    can anyone help me cheers
  9. martin@wolfy
    [email protected]
    Apr 30, 2002
    242
    +13
    Slightly off topic, but does anyone know if the WD My book has to be a home version or can you use the essential edition?
    Wolfy!!!!
