USB external dont seem to be working
Sparky83
Sparky83 said:
I've got a green power led lit up but doesn't show on my pc?
Any thoughts?
Was used as my mac auto back up, will need reformatting I guess but I can't if I can't see it
paulktreg
What version of Windows are you running?
paulktreg
Can you see the HDD in Control Panel > System & Security > Admin Tools > Computer Management > Disk Management?
paulktreg
Driver issue? Are your motherboard USB drivers installed/up to date?
mdbarber
the detection seems to imply the device is reporting correctly until a certain point, can you check the drive on another machine, or at least uninstall via device manager then unplug drive usb and power off PC and drive.
restart both and re attach the usb cable watching for any errors in install.
If its detected as an unknown device this time you will need to power cycle again, this time unplugging the PC from the mains.
Otherwise,, sounds like it may be a drive failure..
Sparky83
I'll have to have a go at the following later on. Strange that it may have failed now, as it was my mac back up until I sold it last week and all I've done is plug it in to my pc
