USB Dual PS2 to PC Convertor XP-any good?
Discussion in 'Playstation Forums' started by Ewan, May 15, 2004.
  1. Ewan
    Ewan
    Hi!
    Just wondering if anyone here had bought a USB Dual PS2 to PC Convertor XP?
    Does anyone have any ideas what games they will work with?
  2. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    mine works with pretty much anything
  3. Ewan
    Ewan
    Hi!
    Thanks:thumbsup:
  4. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    ive got it - same results as above, though there is a small amount of lag for some reason. Nothing major, but it's there.
  5. criggy
    criggy
    Dec 15, 2002
    765
    +81
    hi all
    a mate as just bought this from play but can't get the driver to work
    and i have just tried it on my pc and it won't work either
    we are both running win xp home
    this is what i do: autorun-click set-up-double click set-up
    set-up box appears which is dated 23/09/2001? i click ok
    and another box appears which says copying files and the
    green line fill's very fast and then ding dong and that's it
    but there's nothing under programs
    any idea's?
    cheers criggy
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    it doesnt install any program files - thats why theres nothing there lol. Take a look at
    Control Panel >> Game Controllers
    if all is well, you'll see two devices there, both labled something like "dual PSX-USB convertor"
  7. criggy
    criggy
    Dec 15, 2002
    765
    +81
    cheers james
    checked game controllers but it only list's my sidewinder joypad
    also i only have the driver cd not the converter itself.....doh!
    thanks criggy
