USB card readers not working on unibody Macbook
Discussion in 'Apple Forum' started by danwalton, Jun 13, 2009.
  1. danwalton
    danwalton
    Feb 15, 2005
    2,404
    +131
    Hi, I have a unibody macbook and I am fairly new to OS X. I have a couple of USB multicard readers, both of which are no longer recognised by the mac. I have tried them on different computers and they both work, and have also tried different memory cards (SDs and Memorystick Pro Duos) none of which are recognised. I know that readers in OS X aren't recognised until a card is inserted.
    USB Flash drives work fine, as do USB external harddrives and my PSP in USB mode.
    I have looked on system profiler and the card readers don't show up there either.
    Any ideas? They are both generic card readers, which rules out manufacturer drivers and both worked fine until recently.
  2. huntere
    huntere
    Dec 30, 2004
    1,584
    63
    Perth, Australia
    +237
    Can't really help I;m afraid but I got a Kensington one as it was "known" to wok on OSX and is fine.
    Have you tried Apple forums of no-one here knows.
  3. CamFire
    CamFire
    Apr 26, 2009
    4,695
    Cambridge
    +600
    Test out the USB ports on your MacBook with a (say) mouse and ensure they're working. Otherwise, they'll need looking into by Apple technical support.
  4. danwalton
    danwalton
    Feb 15, 2005
    2,404
    +131
    its very strange really. both USB ports work fine with all other accessories. I'll try apple technical support.
    Thanks guys
