USB 2.0 add-on card
Discussion in 'Desktop & Laptop Computers Forum' started by Dr.Rock, Dec 11, 2003.
  1. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    669
    London, UK.
    +28
    Does anyone know where I can buy a PC card (eg PCI based) which will give me USB 2.0 ports, and will there be bottleneck/compatibility issues with my old Pentium-2 motherboard?
    I'm interested in buying an external DVD recorder for my PC, but it connects to a USB 2.0 port whereas my old PC only has USB 1.1, which is why I want the mentioned expansion card.
    Thanks.
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,308
    Berks, England
    +134
    Bought one from maplin.co.uk. Payed a slight premium for the extra 3 front slots which fits in a floppy drive pay, giving 5 USB2 ports in total. I'm sure they'll be useful one day!
    regards,
    Rob.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    or try:
    www.ebuyer.co.uk
    www.dabs.com
    USB2.0 PCI card should cost you around £15 - £20 all in.
    As long as your P2 is running Windows 98SE or later you should have nop problems with USB2.0
    Check the specs of the DVD encoding/writing software though as this may struggle on a P2.
    Mark.
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    A friend of mine has just bought one of these (pretty sure it's that one anyway - similar price at least! :)
    A useful upgrade if you also think you may require firewire at some point in the future :)
    K.
