Usage of 40gb Sky+ drive
Discussion in 'Sky Digital TV Forum' started by kevpatts, Aug 20, 2005.
  1. kevpatts
    kevpatts
    Aug 20, 2005
    114
    Hey,
    has anyone any experience with replacing the 40gb drive in the Sky+ box? I did this 7 months ago (following instructions here; http://www.boards.ie/vbulletin/showthread.php?t=194008). I've had no problems with my 250Gb drive.
    I'm trying to use the 40Gb drive in my PC with no luck. Has anyone else had problems? It's not a problem with cable, the master/slave settings, the IDE port or the drive itself.
    Thanks,
    Kev
  2. FMC
    FMC
    Dec 29, 2004
    197
    Scotland
    +4
    Have you tried to format it?
