Is there anyway from the rear of a x360 that you can tell if its a american model ?
i was waiting for the wisecracks
no region code or anything on case
psu is the same with a eurolead on it so cannot work it out
however was told its a usa one but region 1 dvd's do not play![]()
The PSU's aren't switching but you can use a UK PSU unit with a US console and vice versa cos the power from the PSU into the console is the same, the only difference is the power into the PSU.
