usa tivo
Discussion in 'Digital TV & Video Players & Recorders' started by weaver63, Nov 18, 2003.
Tags:
  1. weaver63
    weaver63
    hi all :hiya: new to the forum so be gentle.
    can anyone tell me if it is possible to use a tivo unit from the states? and if so will i need any converters or such.
    thanks in advance.
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,408
    WEST MIDLANDS
    +1,403
    Welcome
    You can`t use a USA tivo in the UK for number of reasons.
    1) It would be the wrong voltage.
    2) It would be NTSC only (Uk is Pal tv system)
    3) The internal tuner wouldn`t work in the UK
    4) Most importantly you wouldn`t be able to download the EPG program information as you would not have a UK subscription, Which means even if you could get around points 1,2 and 3 it would be little more than a HDD vcr ?
    Apart from that it would probably work fine ;) :smoke:
  3. weaver63
    weaver63
    thanks for the info carlos.
    sorry did not reply sooner had a little computer breakdown.
    ps. where could i get a tivo from then
  4. lyghthouse
    lyghthouse
    Nov 21, 2003
    20
    Wigan
    Try http:\\www.ebay.co.uk
  5. Azrikam
    Azrikam
    Or Here . They've got a dedicated thread for finding TiVos. (but eBay is still your best bet, I think)
  6. mjn
    mjn
    May 24, 2001
    21,408
    Herts, England
    +8,966
  7. ji_
    ji_
    Dec 1, 2002
    57
    in transit
    Yeah but can't you use a stepdown transformer, on a TV that accepts NTSC (as most modern ones do), ignore the internal tuner and just use it through the Sky box or whatever, and as for the alst one why wouldn't TiVO sell you a sub? Its all money to them after all!
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    The USA TiVo not only outputs an NTSC signal, but will only receive NTSC as well and a Sky digibox etc will only output in PAL. You would need to spend about £200 on a digital standards converter to get it to work. At this price you might as well buy a £200 UK TiVo.
    TiVo wont sell a UK sub for a USA TiVo because the data for the UK is very different to that for the USA and therefore would not be compatable with a USA box.
    Mark.
