USA PSP in the UK. Will it work ?????
Discussion in 'Playstation Forums' started by jerkyboy, Mar 10, 2005.
  1. jerkyboy
    jerkyboy
    I have just read on the Sony website that the USA PSP comes with a 100V - 240V, 50/60Hz AC Power adaptor. Does this not mean that it will work in the UK ?.
    Thanks for any feedback
  2. Spoonman2
    Spoonman2
    Dec 28, 2002
    3,672
    137
    Ashford, Kent
    +600
    You`ll just need a simple convertor.
    Spoony.
  3. jerkyboy
    jerkyboy
    Where would I get one from and how much do they cost ?
  4. nero0410
    nero0410
    Jan 5, 2004
    12,702
    Weston Super Mare, UK
    +5,051
    They are generally quite cheap.
    There is a site HERE that isnt bad. Quite quick delivery too.
    Other than that try down at your local electricleshop, one that sells all different wires, cables, plugs etc.... They should have one or at least point you in the right direction
    tris
  5. jian
    jian
    Aug 31, 2001
    2,576
    68
    +77
    Why would you need one of these when the included power supply is multi-voltage?
    All you will need is a pin converter.
  6. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    What this means is you just plug in th epower lead from an xbox, video, dvd player, ps2 you know the sort. Plug on one end and a figure of eight connection on the other, cost about £2-3 if you don't have a million spare ones knocking around from old equipment!
  7. nero0410
    nero0410
    Jan 5, 2004
    12,702
    +5,051
    True, didnt think of that.
    good thinking batman. :)
    tris
  8. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,403
    Bristol
    +10,110
    Lucky thing you can use the PS2/XBOX power cord as my PSP arrived just after xmas and was missing the promised plug converter so was confused for abit on how I would charge it but only took my a few mins to figure out there wasent a problem :)
