usa ip address help
Discussion in 'Networking & NAS' started by Blade2005, Jan 10, 2012.
  1. Blade2005
    Blade2005
    Apr 8, 2005
    322
    +6
    hi can some some please tell me how to change my ip to a usa based address so i can unblock some youtube videos that are blocked in the uk
    i am using internet explorer i understand that i need to go to tools / internet options / connection...... but then am not sure what i need to change
    is it possible to just change the ip address for viewing youtube.com only?
    as i don't need it for any other site
    would that be safer so the owner of the IP address cant follow what sites i go to and find my usernames and passwords for forums and stuff like that
    also can someone tell me how to remove the usa ip after using it and return to using my ip address only
    thank you
  2. rednotdead
    rednotdead
    Jun 4, 2005
    462
    28
    Hampshire
    +44
    Not possible for a variety of reasons.
    To achieve what you're trying to do google for web proxy...
  3. LJx
    LJx
    May 29, 2009
    3,252
    uk
    +436
    you could use a vpn but that would probably be a waste of money for a few videos. If you download anjd install hotspot shield it should work for what you want Hotspot Shield
  4. mjn
    mjn
    May 24, 2001
    22,910
    Herts, England
    +11,055
    a proxy is your best bet.
