You can import a drive from the US or Asia as the power supply is compatible (but you need a figure of eight lead (3 amp fuse)http://www.stuff-for-computers.co.uk/acatalog/cabket.jpg. Well used importers include www.movietyme.com and www.play-asia.com
Consideration of importing can be warranty validity and cost.
Thanks guys, should of looked sorry. So all I need is the 3 pin 'kettle lead' for it?
not a kettle lead!
8 lead.
Theres an FAQ in the hd-dvd section but yes you can
all hd-dvd's are also region free
I'm planning to buy European model of XBOX360 and HD-DVD add on.
Since I still have SDTV (PAL only) will it play HD-DVD disc purchases in USA?
I could always connect it to PC monitor which supports both PAL/NTSC. Am I right?
