US xbox via component to Philips LCD
Discussion in 'Xbox Forums' started by Warp, Feb 12, 2005.
  1. Warp
    Warp
    Jan 5, 2005
    69
    I have just hooked up me US Xbox with hi-def pack component lead via some adaptors to the DVI socket on my Philips 37" LCD (37pf9986). However all I get is the message "Picture format not available".
    I have read about modded UK xboxes that you select the type of picture you want the Xbox to output (e.g. 480p). I cannot see similar options in my US xbox setting. Is this because it will by default output 480p if the hi-def pack is connected? Anyone got an idea why I can't get a picture (my TV is compatible with a 480p @ 60hz signal)? I get a picture when I use an RGB cable.
