us xbox live
Discussion in 'Xbox Forums' started by lostsoul, Apr 30, 2007.
  1. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    hi guys, im just wondering if it is possible to get an xbox live 12 month card from the US and use it here. Cheers khaggy
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    N Oreason why not, the live codes are not region specific as far as I am aware..
  3. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    I think theres an issue with the 12+1 cards , not sure 100%
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,153
    Bristol
    +9,897
    I am pretty sure the 12 month Gold cards are region specific so would only work with a US account.
  5. NewBeetle
    NewBeetle
    Oct 19, 2002
    11,552
    NW
    +3,414
    My US 12 Month gold code,from ebay.com worked perfectly fine on my UK 360.
  6. roadie
    roadie
    Feb 20, 2007
    742
    +5
    when did u buy the code?
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,153
    Bristol
    +9,897
    Things must have changed then because I remember on here just after the 360 was launch people were complaining that imported subs from the US would not work.
  8. NewBeetle
    NewBeetle
    Oct 19, 2002
    11,552
    NW
    +3,414
    About 4/5 months ago
  9. KevD
    KevD
    Jun 10, 2005
    10,703
    +1,563
    My imported sub (ebay.com) work from around the lauch of the 360 fine. Its the MP points that dont work. :thumbsup:
  10. runner05
    runner05
    Jan 15, 2006
    440
    +13
    also using us subs here, bagged 4 years from ebay.com at $20 a year it would have been a crime not to:lesson:
  11. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    Thanks for the replies guys! i guess i better risk it lol im just wondering just to be safe, what are the disadvantages of creating a US account or just using it with a uk account?
  12. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    Oh and another thing, how would i be able to add to my subscription once the 12 months are up?
  13. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
    You wont be able to access the content on the UK Marketplace. Apart from that it will work exactly the same. Still be able to play online with people etc.
    You dont need to create a US account on your 360 to use the US Live subscription though. Just add the code to your UK account and it will work fine.
    You will only need a US account to access content on the US Marketplace. Then if you wish to purchase any content you will need US Marketplace Points.
    As other have said Live subs are not region specific, whereas Marketplace points are.
    There's an option in the dash called "Redeem Code"... just type in there. Also, you dont have to wait until the 12 months are up before adding a new one as you can stack them.
    I bought my 12 month sub from a US eBay seller. He emailed me the code within 24hrs too. I think it cost me about £18 or something like that.
  14. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    thanks for the detailed reply! it really cleared a lot up for me. once i use the us 12 months card would i then be able to use a uk card to top up or would i still hav to use a US card ?
  15. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    +2,948
    No probs man.
    You can then use a UK one again if you want, after using a US one... but at the price they are over here you're best just sticking to the US ones!
  16. is1111
    is1111
    Mar 17, 2005
    1,754
    83
    Glasgow
    +280
    just be careful with the US subs as there are definitely ones that don't work.
    i had to add 12 months to my account in march and spent a while trying to get a cheap US one that would work. see this post:
    http://www.avforums.com/forums/showthread.php?t=466482
    there is definitely issues with the newer style 360 gold US cards. i seen UK sellers trying to sell US codes back to people in US as they didn't work here.
    i also have a friend who used a US one from ebay to open his account here no problem last year but then bought another for his nephew this year and it wouldn't work here at all.
    the 12+1 month definitely can't be added to an existing UK account and there are other 360 gold style cards that won't work either.
    i think some of them can be used to create a new account in the UK but not extend a current account.
    if you can find the old style xbox 12 month cards then i'm pretty sure these work ok.
    in the end i didn't see the point in taking a risk to save a few quid so bought one from a european seller that was cheaper than getting one here.
    if using ebay you could always ask the seller if they will email the code and if it doesn't work will they give you a refund.let us know how you get on as i wouldn't mind picking up a cheap one myself.
  17. DazzaSammy
    DazzaSammy
    Dec 31, 2006
    395
    46
    Carshalton
    +111
    Can anyone please confirm asap that if I buy Points for Live off ebay bought in the UK I can use them on my US Live account.
    Or only american live points will. Thanks
  18. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    dazza sammy do you use US live on ure xbox 360 and if you do where to you get it from and what type of card did you get and when? cheers
  19. DazzaSammy
    DazzaSammy
    Dec 31, 2006
    395
    46
    Carshalton
    +111
    I am in UK on UK xbox but have 2 Live accounts. I want points for US Live but have bought UK points and dont think they work on US Live account.
  20. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,153
    Bristol
    +9,897
    No you cannot use UK points with a US account as the points are region specific.
  21. DazzaSammy
    DazzaSammy
    Dec 31, 2006
    395
    46
    Carshalton
    +111
    Thanks for that, didnt want to waste money on Ebay. Ta :smashin:
